Hi i have bought Beocentre
This post has 5 Replies | 2 Followers
stevehouse
Posts 1
stevehouse Posted: Thu, Apr 27 2017 1:23 PM
Hi
I have bought a  Beocentre 9300
I want I Beogram to go with it, can anyone tell me which model was originally assigned to the 9300 ?
Thank you
Steve
leosgonewild
Helsinki, Finland
Posts 2,373
Beogram 9500 or 4500.
leosgonewild
Helsinki, Finland
Posts 2,373
4500 and 9500
stefan
200 miles from Struer
Posts 2,920
stefan replied on Thu, Apr 27 2017 3:54 PM
BG 9500 won`t work (no RIAA) - 4500 will work. Also 3500, 6500, 7000 will work.
Designwise I`d choose a 4500 or a 3500 with mirror top I think (I really don`t remember, whether the 9300 has the white stripe the 9500 got).
You can also use any other Beogram, but you will need an external riaa amplifier.
Hope this helps
Stefan
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Steve,
Welcome to Beoworld!  If it helps, here is a link to a guide that I've put together which lists all the Beogram turntables that would need a pre-amp if used with the Beocenter 9300:-
http://www.soundsheavenly.com/faq/question/beogram-turntables-need-external-pre-amplifier-kit/
There are details in the link of recommended pre-amps with cables to get everything working if you choose a Beogram that needs a separate pre-amp.
Kind regards, Steve.
Steve.
leosgonewild
Helsinki, Finland
Posts 2,373
My bad Unsure
Page 1 of 1 (6 items) | RSS
