2 center chanels
liviu_o
Posts 157
liviu_o Posted: Sun, Aug 19 2012 5:01 PM
Hi! Anybody have tried to use 2 center speakers?
I am concerned about delays and maybe subtle tone discrepancies.
As you probably saw in my other topic I am using a beolab 6000 as center speaker and I am wondering ( as my Rotel rsx 1057 has 2 center pre outs) how will sound my system with 2 6000's as center speakers.
Ad the second thought: it will be both front or front and rear?
Thanks!
gizze
Posts 39
gizze replied on Sun, Aug 19 2012 5:43 PM
I think it can work really well. I ran my cinema room with 2 centres for a while, helped really lock the vocal in the centre of the screen, I ran one above and below the screen though.
Only issue I can see if you want to run them either side is anyone sitting of to one side may loose lock on the screen slightly.
Michael
Sweden
Posts 2,578
Michael replied on Sun, Aug 19 2012 5:47 PM
It will look terrible. But should work..
2012martin
Posts 202
Some people use two 4000s
kallasr
Germany
Posts 2,562
kallasr replied on Sun, Aug 19 2012 6:54 PM
I will try this week to use 2 center speakers BL4000. With a pioneer avr pre-outs. I will post on this forum. Oh, and my new used BL8000 as fronts.
Ralf
Michael
Sweden
Posts 2,578
Michael replied on Sun, Aug 19 2012 7:41 PM
2012martin:
Thats much better since they look very good together. I am also looking in to this solution, but hard to find good used cheap bl4000, in the right colour :). I want two silver with black frets that would match my bl8000 and pentas.
2012martin
Posts 202
I use a 3500 as a centre speaker to match my 8000s looks very good. Would probably look even better with 6000s. I've had the 3500 modified so it acts as a Normal speaker using the power link socket instead of the masterlink socket.
2012martin
Posts 202
Page 1 of 1 (8 items) | RSS
