Beolab 8000 problem
This post has 4 Replies | 2 Followers
liviu_o
Posts 157
liviu_o Posted: Sun, Aug 19 2012 10:14 PM
Hi!
My "new" used 8000's arrived and they're nearly perfect....nearly because I have a small problem:
- they turn on ....work as long as they receive signal....then when signal is off ( during a movie, or concert) one of them is turning off and the other turn off but turn on imediately and off again...very quickly...as a sort of clipping.
- if I turn off the movie/concert....they are off both of them without any problem.
Anybody encountered this sort of problem?
Thanks!
Michael
Sweden
Posts 2,578
Michael replied on Sun, Aug 19 2012 10:34 PM
liviu_5F00_o:
Hi!
Thanks!
Are you using the line in connection? In that case the speaker will turn off when it feels that the signal is to weak. This occurs on low volume and makes the speakers turn on and off when there suddenly is more sound and then again less sound.
liviu_o
Posts 157
liviu_o replied on Sun, Aug 19 2012 10:39 PM
Yes, you are correct. I forgot to mention that I am using "line" input.
I agree with you, but as long as one loudspeaker is "quiet" the other turn on-off-0n-off..... very quickly...almost every second...very unpleasant.
tournedos
Finland
Posts 7,357
tournedos replied on Mon, Aug 20 2012 7:23 AM
In LINE mode, once the speaker has turned on, it should stay on for some time (30 seconds or three minutes, can't remember) even if the signal goes away.
Try swapping the speakers around; if the issue remains on one of them, it has some kind of a fault.
--mika
liviu_o
Posts 157
liviu_o replied on Mon, Aug 20 2012 8:43 AM
Yes....it stays on for about 30 sec and then, when the other speaker turn off this one is going on/off/on/off....repeatly
Page 1 of 1 (5 items) | RSS
DigiCert Secured Site Seal
