Motor Stand from BV10-40 on a BV11-40
georgey007
Posts 74
georgey007 Posted: Thu, May 18 2017 6:10 PM
Hallo
Does anyone know If the motorstand from abv10-40 will fit and work on abv11-40?
Regards
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Thu, May 18 2017 6:58 PM
You can mess around with (and replace) the rear fittings and eventually it'll hang on there - but the motor part of it won't work as it's totally different on the BV11 (fitment).
Lee
georgey007
Posts 74
Thanks for the quick answer Sad
Page 1 of 1 (3 items) | RSS
