BV10 issues
This post has 3 Replies | 0 Followers
plumber77
Posts 76
plumber77 Posted: Mon, May 1 2017 7:59 PM
Hi
My Beovision 10 has started acting up
It will switch on and the screen comes on for approximately 5 minutes then the picture splits in half.
Half the screen is still from whatever is on whilst the other half shows the current TV images then approx 5 minutes after the display disappears.
Last time it went blue.
Sound remains ok.
If I turn it ff then on again there is sound but no display.
If I leave it off a while it starts up OK again before going through the previous issue.
Any help appreciated.
Cheers Mark.
peterafox
Posts 34
peterafox replied on Wed, May 3 2017 11:38 PM
Doesn't sounds good. Have you updated the software to the final version? Perhaps worth a try. I downloaded it and installed via USB a year ago or so which updated the interface etc.
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Wed, May 3 2017 11:59 PM
Is this when using the internal (inbuilt) freeview?
If not, what happens when you connect an external source, like a DVD Player or Sky Box?
Lee
plumber77
Posts 76
Thanks for the reply.
No happens on sky, freeview and apple TV
all are connected.
I tried turning external sources off and using freeview only as the last attempt but it still occurred
Page 1 of 1 (4 items) | RSS
