I just got an old beogram 3000 type 5901 witch plays well, but when playing it sends a 20-30 sec. beep sound to the speakers. It is connected to a Cambrige azure 650 amplifier with a NAD PP2 RIAA. I think it might be a problem with the beogram, but i would like to hear if other have had similar problems before?
/Peter
It will be the arm motor which suggests the earth is not perfect. How is it connected? Does it have a DIN plug or RCA plugs?
Peter
Thank you, I will try and ground it better. The beogram has a DIN plug who have been converted to RCA plugs for the RIAA. I initially suspected the converter as the problem but it is brand new(although the quality is not very high).
