HDR2 - Dark Picture on BV7 - Help pls
This post has 2 Replies | 2 Followers
ultraviolent
Posts 30
ultraviolent Posted: Sun, Aug 26 2012 8:51 PM
Hi there,
I'm just cabling our new home and have an issue with our HDR2.
The recorded picture is very dark and I don't have any clue what to do against it. The aerial is looped through and the TV picture is perfect but recorded stuff and the on screen menu is very dark...
any ideas?
Regards
Stephan
Raeuber
Germany
Posts 2,542
Raeuber replied on Sun, Aug 26 2012 9:34 PM
Hi Stefan,
try to adjust the brightness in the (hidden) service menue of HDR2:
Go in menu of HDR2 to SETUP and press GO
Go to EXTRA and press 0 0 GO
In AV BOARD MENU select PICTURE ADJUSTMENTS
There you can adjust the settings of the picture, especially BRIGHTNESS
Hope this helps!
Regards
Räuber
ultraviolent
Posts 30
Thanks for the help Raeuber, the hidden menu also has the menu option " RGB output ", I switched this from "on" to "off" and the picture is now almost perfect.
Many thanks for the quick and useful answer,
Stephan
Page 1 of 1 (3 items) | RSS
