BeoVision 11-55 > plex or kodi
This post has 9 Replies | 3 Followers
crossbytje
Posts 224
crossbytje Posted: Fri, Feb 10 2017 9:59 AM
I may be in the market for a used BV11-55 and have some questions to which I can't quickly find an answer.
There are (limited) smart tv functions on the BV11, does anybody know if it is possible to have a plex app or kodi app on the tv? Or am I forced to connect a mac-mini and control it through PUC?
Is the music player any good? Can it read a shared itunes library and can it be controlled using an iphone app without the need for switching on the BV manually with the beo4? Is it responsive, or slow as hell?
What I really want is to play my own music (no deezer or spotify, but an itunes library (which I could put in a DLNA server if necessary)) through the connected speakers, preferably without the need for the screen to be on. It would be great if my beolit12 could join in seamlessly (which it does now, see below).
Second, I want to watch movies and series (mkv files, some lossless, others compressed), be able to download missing subtitles, using only one remote.
I'm currently using kodi on an old macbook connected to an LG screen. I have to manually switch on my tv, the sound receiver/amp, and to use my mac remote for controlling kodi. Apart from this, it really works pretty good. My macbook is never switched off, I can remote-control itunes from my iphone and it plays simultaneously on my beolit12 and through the surround system in the living room. Ideal to put the beolit on the terrace, or in the kitchen and have multiroom functionality. It just works, when I'm working in the office upstairs, I can take the beolit, use the iphone to press play on the itunes of my macbook, and the beolit simply takes up the sound, without the need for the speakers downstairs to be switched on.
I'm afraid the beolit will not be able to join the beovision's sound, but I could live with a hidden, always on, mac mini hosting my itunes library. In that case, Is it possible to program a button on the beo4 which would switch on the BV in audio mode (picture mute) using the same hdmi source as would be used for watching the kodi application? While having another button to switch on the BV in movie mode for watching kodi?
Thanks for your input!
Beolit 12 - Beolab 4 pc (dead now) - Beoplay H5 - Beolab 9 - BeoRemote One BT - Beoplay M3
Sandyb
Posts 2,186
Sandyb replied on Fri, Feb 10 2017 10:11 AM
Not an expert, but the11-55 will be able to see Plex (and i assume Kodi as well) through its HomeMedia source / input.......what you get is a folder structure i think....i did it briefly, but in the end just plugged in a USB drive to my TV (12-65) to get to the same outcome..........if you want the Plex UI, you will need to do it through an external box (ATV4) or your mac mini.............as for managing the media library using one remote, the tv itself can't do that (the HomeMedia function), but may well work through an external box.....i think thats how most BV owners, who use media servers, do it.......as for music with the TV off,  if you power on your BV11-55 system using the remote straight to the (media server) source, the screen will come on.....you can play music, and then flick the picture off, but it will come on initially i believe.......others may know if you can save the preset to have picture muted.....
Sal
California, USA
Posts 1,197
Sal replied on Fri, Feb 10 2017 3:09 PM
@Sandyb is right on everything said:  I've got a BV11, and the HomeMedia source can see the Plex Server, it is presented as a raw folder structure. (I'm also assuming since the BV11 is a DLNA receiver, it will see Kodi and other servers too). The BV 11 will have to be "on" in order to play sources, but the picture will turn off (in settings) automatically after a few moments. The LED on the upper right portion of the television's frame will be Green when the screen is off letting you know that the TV is "on."
I use the HomeMedia function quite a bit on my BV11 to play music through connected speakers, and it is quite good. Again, simple folder structure, but it does the job, and shows the album art and a progress bar. It is bare bones functionality though, play, pause, volume, and tracking and maybe shuffle, though I haven't used that. I'd recommend using an apple TV and manually turning the picture off if you want more functionality like Play NExt, etc.
As for using the iPhone to control the BV11, yes, the BeoRemote App can control the BV11 and other B&O products, but the BV11 must not be in the powersave mode for that to work (again, settings). You asked if the BV11 is responsive, yes it is. I wouldn't say that the "smart" functions are responsive, hence I don't use the smart functions at all. No apps, no nothing.
I've got an AppleTV connected to it if I want a more pleasing experience with Plex or music playing (among other apps of course).
You also asked about a shared iTUnes library. The BV11 by itself can't see the shared library like the ATV can. You'll have to run a barebones server pointed to your iTunes/Music folder in order for HomeMedia to see your music folders.
At one point I did the same as you: had an always on Mac (Power Mac [cheesegrater]) connected to the BV11 via HDMI adapter cable and controlling functions  with an app called "remote buddy" which allowed even more control of the Mac via a GUI remote on your iPhone. But then I moved to running my iTunes library and Plex on a QNAP NAS. A separate profile on my main computer is the "brains" for that Media so whenever I need to make adjustments or add music / movies, I log into that profile, mount the NAS as a network drive and Plex and iTunes on that profile see the storage and I can make changes, etc. Then I log out of that profile and the NAS keeps chugging along. It uses less power than an always on computer -- though a Mac Mini is a pretty great always on machine as a server.
Your final question about button mapping, the buttons are mapped to ports on the back of the BV11, HomeMedia, WebServices, etc. So you'll have to have separate sources / ports mapped to each button. For example, HDMI1 if mapped to TV, that port (HDMI1) won't be available to map to DVD. And Vice Versa, so if you want to do the same thing from one port, but with a slightly different setting, that's going to prove to be next to impossible. What you can do, though is to look into something called LinTronic, which would allow you to create macros perhaps allowing you for more refined and complex control of how the BV11 reacts to certain button presses, only brainstorming here.
I say the path of least resistance for you is to perhaps invest in a Mac Mini with an external HDD, run plex / kodi / iTunes on it, or keep using your MBPro to run Plex / Kodi / iTunes, and have the BV11 be the receiver for it, either using HomeMedia, or a more elegant approach is purchase an AppleTV, to be your BV11's "receiver" for the media you've got on your MBPro.
Sorry for the long winded response.
Kevin Waldron
Orange County, California
Posts 20
Try JRiver on your PC and JRemote on your iPhone. I have that setup with a Beovision 11 connected via DLNA renderer. Simple and elegant.
crossbytje
Posts 224
crossbytje replied on Sat, Feb 11 2017 12:16 PM
Thanks for the replies!
Seems like I'll probably have to get a mac-mini tucked away somewhere. Not so sure whether an apple TV is tough enough for rendering bluray uncompressed remux mkv files (which are some 40Gb per movie). I've read a bit into the Apple TV and it may even require a jailbreak to get what I want.
I guess a mac mini is the easier solution + it simply works as a computer in case I want to slideshow photos, or present/discuss travel plans to family members. (For I haven't seen any good and responsive solution for showing photo's on screen, without having sorted them really nicely beforehand. Simple mouse and keyboard seem to do the trick much better for me.)
What may be a possibility is to have the media center software (either kodi or plex, but I lean towards kodi as this is what I'm used to now) send its audio through the HDMI interface, while having the regular audio (itunes) play through the optical out of the mac. That way, I could map two different sources and use the BV in two different 'modes'. I'd have to rely on a PUC mapping of the beo4 commands to mimic an apple IR remote to control kodi.
I'd have to check if a mac is able to use both audio outputs independently.
Apart from this, I've been looking at some BV11 reviews, and the input lag seems to make it hard to use it as a monitor for a computer. I guess these reviews are from the first versions and that some firmware upgrades have already significantly reduced input lag. Is this true?
Sal
California, USA
Posts 1,197
Sal replied on Sat, Feb 11 2017 4:37 PM
crossbytje:
There's a "GAME" mode which is supposed to reduce the input lag if I'm not mistaken.
crossbytje
Posts 224
Yeah, but even in that mode, the input lag was still considerable. Anyway, I just searched a bit (I remembered a thread on the input lag of the BV11) and found that there was indeed an update, somewhere 2014, that reduced the lag to acceptable figures, so that's good!
With regards to the mac mini, I've just tested another 'old' macbook I had laying around (an early 2011 MacBook Pro 15") and found that it can indeed output two different audio signals. It can pass digital audio with the video feed through HDMI (from kodi eg.), while simultaneously sending digital sound through the optical out (from itunes, both playing different stuff at the same time). So it could be connected to two separate sources on the BV. At least, if the BV allows assigning the spdif input to any source. I've searched the manual but it is not clear whether the spdif could be used for a 'music' preset on the BV? It says somewhere it could be used for a computer input, but it will probably not allow the spdif to be assigned to a disconnected hdmi port?
Millemissen
Flensborg, Denmark
Posts 14,680
crossbytje:
Indeed it can.
I use the SPDIF-in on my V1 (will be the same on the BV11) for the digital-out of a ChromeCast Audio dongle.
You can configure the (sound) settings of that source just as you need it.
crossbytje
Posts 224
crossbytje replied on Sun, Feb 12 2017 12:48 PM
That's great news!
(The BV I had my eyes on was sold before I could go and look at it, which is a bummer. On the other had, I'm not in a hurry, still awaiting my 10y old 720p LG to go out (with a bang?) Until then, I keep a close eye on the second hand market.)
Cliffordsome
Posts 1
Kevin is correct, there is a very simple solution: run JRiver on the Mac to present the files using DNLA to the Beovision, and the Beovision will show the music files when you are in BeoMedia.  They present as folder structure and also artist / album etc.
You just need to make sure the mac on which this files are stored has not gone to sleep.
You can either control the music using JRiver app on an Iphone, or JRiver on the Mac (select Beovision 11 from the "playing from" menu).  Or you can "manually" navigate through using the B&O TV controller.
Should work beautifully.
Page 1 of 1 (10 items) | RSS
