Hello,
Can I connect BeoCord 1500 De Luxe Reel to Reel Tape Deck to Beomaster 900K?
As I know there is some issue with volume control for tape connection.
Thanks.
Welcome to Beoworld !
It'll work fine.Which volume problems related to the tape input have you heard of?
(This is my third - and final - attempt at posting this. If this fails too I'm sorry I cannot be bothered trying again)
Hi Martin,
Thanks for info.
I read this on some forum, but I can't find the link.
I have Beocord 1500, so I need some amplifier, I want to buy something from same years. Beomaster 900 good choice? What you think?
Also I need DIN to DIN cable, maybe do you know where I can find the original or good quality one?
Arman
Or a Beomaster 1000, or even better a Beolab 5000!
For DIN cables, look at the bottom of this very website...
Jacques
Thanks!
But Beolab 5000 is totally different thing)
