Hello,
I am thinking of extending my masterlink system with RJ45 cables and I was wondering if someone has tried using flat cables like this one:
http://www.vpi.us/cable-flt-cat7.html
It is a flat cat7 cable.
Also, I have seen some documentation around the installation but have never seen anyone using a junction box to connect the wires (which would be my preferred alternative). Is there a schematic somewhere which shows which masterlink colors that I should connect to the cat7 cable?
Best regards,
My B&O products: Beosound 9000, Beosound 2300, Beosound Century, Beolab 8000, Beolab 6000, Beolab 4000 x2, Beolab 3500, Beolab 2000, Beolab 10, Beolink Active x2, Beotime, Beo5 x2, Beo4, A9 keyring x2, LC2 dimmer x6 and growing....
Thanks for the suggestion, the thing is that I am unable to tun the cables in the walls and a flat cable would be much easier to hide...
