I just got a Beomaster 9000 and am wondering with which reciver I can pair it. Would it work with a beomaster 3300 or should it be the Beocenter 9000,9300 or 9500. hope you can help.
Kind regard
The Beogram 9000 works fine with the BM 3300. The BG 9000 is basically the same as BG 3000, 3300, 5500, 9500 and many more.
Thnx, and a special thnx for looking past the error in my question ;)
