Hi, I wanted to know if it is bad for the battery leaving the Beolit permanently plugged in? Does it use a pass-though when playing off the mains and bypass battery?
Hello - I can't answer your question, but I will share my experience. I have a battery issue with my Beolit 12. I have never used it unplugged, and it is completely dead suddenly. I am unable to reset it. That makes me think that if the battery goes dead - not just discharged, but dead - you are out of luck. Apologies if this isn't helpful.
