I had a power outage & lost Twonky Server from my Beosound Moment. It doesn't even say none. I don't know where to enter the key. Please help!
Sorry, what do you mean by 'even say none' - (probably you mean can't select it for now)?
Did you go into the settings, where the Media Server is choosen?
Still don't there?
And what do you mean by 'enter the key'?
The licence key for Twonky is added in the UI of Twonky - on the NAS, Pc, Mac where the server should be running?
Are you sure that this device and the server is running properly after the 'power outage'?
