So I have a Beosystem 5000 which works mostly great. But recently, it started automatically turning down the volume at 40 - always keeping a steady 38-40 - which is very annoying, as you can imagine when you want to listen to anything remotely loud.
At first I thought it was an automatic muting, but couldn't make it stop using the Master Control Panel either.
Anybody ever have this problem? Or know how to fix this?
This is a feature of the design,to protect the amplifier and speaker's.
What speakers are you using,are they B&O?
The system should play loud,but will self protect if the loading of the amplifier is too great,eg,if speakers are too low impedance etc.
Nick
