Hi All
I have 2 restored Belab Penta MK1 amplifiers just standing in the closet, bought them for fun to see if I could get them back to life.
Now they are fine again, and I have talked to a guy who owns a Beomaster 8000 with a set of Beovox Penta's.
He has asked if he would benefit using my 6601 amps instead of the 2*150W of the BM8000.
What do you guys think ? I have never heard the BM8000, but I have read a few threads, and some people think it is one of the best amps built by B&O ?
1. What would you do ?
2. Can the BM8000 be connected to the MK1 amp ? It only hase lineIn / Speakerlink and Amp Level In.
If I set the Sensitivity switch to MIN, which means amplifiers over 25W, will that work ?
I am in doubt whether he will benefit at all, or even if the MK1 amp can handle an 150W amplified signal from the BM8000 ?
Any good points or ideas ?
/Jacob
I would try the BM8000 with the beovox then the mk1 amp and report your impressions
I am working on a set of beolab pentas mk1s this evening as we speak
Saint Beogrowler: I would try the BM8000 with the beovox then the mk1 amp and report your impressions I am working on a set of beolab pentas mk1s this evening as we speak
But is it actually possible to connect a BM8000 to the Amp Input terminals on the MK1 amplifier ? Can the Amp handle the 150w input from the BM8000 ?
Saint Beogrowler:I'd just use the rca pre-out on the side of the BM8000 to the line-in on the penta.
Didn't think there was pre-out on the BM8000 ? can you send me a link with images or something that shows where that is ?
But that would of course be the optimal solution.
Weebyx:Didn't think there was pre-out on the BM8000 ? can you send me a link with images or something that shows where that is ? But that would of course be the optimal solution. /Jacob
Hmm, but is that a proper Line-out ?
If the clamps are removed, and L/R phono is used, is it then possible to adjust Bass/Treble and so on ?
Are thought they only were for Equalizers and other sound control units, not for speakers ?
