I have some new Beolab 5's, I turned them off whilst on holiday and now need to put the pins in (which I have), but how do I this with the beo6? everything refers to the beo4.
Thanks in advance
Paul
I would suggest pressing the + button on the Beo6 screen which should bring up the numeric screen. Then just enter the PIN number. You will know if it works if the speaker reacts to each digit.
Peter
