Hi all :)
I have a beov 1 that once plugged in, doesnt go into standby (i.e. no red light). Is not a power lead issue. Just sits there blank.
Its very frustrating.
Anyone had a similar problem or know what might be?
Thanks in advance.
Will
Hello - and welcome to the forums.
With no offence; have you noticed that there is a power switch? It's located beneath the screen, next to the AV3-connectors on the right-side (I think, couldn't find a picture of it right now). When I got my BV1, it took me couple of days to notice it!
Hello and thank you Iausvi
Absolutely no offense taken. You are absolutely right. Button is there and i didnt notice it. Sorted.
Aaaaand rather embarrassingly Ive owned a bov 1 for some 5 years.
Again thank you.
