I want to trigger my Philips Hue Light if i press CD on Beo4 with my MLGW in my bedroom with a BeoLab 3500. The Light command works perfectly. I used custom strings to switch the light on for example but i can't make a macro where i can trigger the Philips Hue custom string with pressing CD on the Beo4.
If i make a new Macro i can only select BeoLink Control and BeoLink Light Commands.
Is it not possible with the MLGW and only works with the newer BeoLink Gateway? Can anybody help me?
Beoworld app with direct photo upload and emoticons.
Ok, so this is only possible with the BeoLink Gateway and Netlink products and not with ML products?
I don't think it makes a difference NL or ML.
What you need to do is make a scene that when a control key is pressed starts your CD and turns on the light. That's what scenes are for, triggering several elements at the same time.
p.
