Hi
Is there a quick fix for the following? On switching power on to the unit, the door will close, but after 2 seconds the door open and stay open...
Any suggestions gratefully received!
Cheers
Nigel
Take the glass off and give it a proper clean. Also hoover off the fronts of the frets, paying attention to the little black strips in the centre.
It could be picking up a 'false' detection, so to speak.. caused by dirt - and not someones hand.
Lee
Hi Lee
You're a star. Now working perfectly.
Always a pleasure, never a chore.
