New Avant 55 Help
This post has 5 Replies | 0 Followers
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Sun, Oct 29 2017 6:49 PM
Hello all
Today I finally said good bye to my BV7-55
I am now the proud owner of a Avant-55
Looks much better in my lounge
Not have a 7-4 for a centre is different.
I configured my Lab9’s, as front left and right. Set the avant left and right speakers to none as they were also on front left and right.
One thing I am confused about after having a Bs3 video engine
I have configured one Sound mode called TV and setup 5.0
On my old TV when a normal non Dolby source was on it would only switch on front and centre speakers, if Dolby was detected it would switch on the rear speakers when needed.
Is this still the case or am I doing something wrong ?
Also I bought 3 x PL to RJ45 connectors and only went and forgot the RJ45 IR
Now I do have a RJ45 crimp tool and can crimp a cable and cut the old headphone socket off
Does anyone know which pins I should connect to the original cable?
Orange and white
Orange
Green / white
Blue
Blue white
Green
Brown / White brown
Brown
Which 2 do I solder to the original cable so I can control sky?
Thank you
Sean
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
Oh and I currently miss the really clear vocals of the beolab 7-4
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Millemissen
Flensborg, Denmark
Posts 14,680
Seanie_230:
Didn’t you configure the 3 internal speakers of the Avant as a/one center channel for the tv/5.0 group?
Seanie_230
UK
Posts 2,278
You are a star
i have now configured center left and right both as additional center front speakers and it sounds great
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
Seanie_230 replied on Mon, Oct 30 2017 10:36 AM
So being a man I did not read the manual and have some answers to my questions.
If you setup a few speaker groups the TV will swap to the best one for the program you are watching IE Dolby or not Dolby.
I setup one group with all speakers and that it why the rears never turn off.
I found the place where I can configure a perm speaker group per input / source
I have also got the answer to my question about IT transmitter, if I cut off the jack its Pins 5&6 or 7&8 saving me £20 on a new cable.
Sean
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Guy
Warwickshire
Posts 2,590
Guy replied on Mon, Oct 30 2017 11:42 AM
Seanie_230:
It's a bit pricey, but you could always use one of these instead: https://www.ebay.com/itm/RJ45-PUC-A-B-Adaptor-Cable-for-B-O-BeoVision-Avant-55-75-85-11-12-V1-5-M-/152664454264
Out of interest, where did you find the IR transmitter RJ45 pin data?
Cancel that - found it here: http://archivedforum2.beoworld.org/forums/p/20907/175847.aspx#175847
Page 1 of 1 (6 items) | RSS
