As well as my ears going off with age, my memory appears to be going the same way....
I've referred to the manual but can only see how to do it with a MCP. Can somebody remind me how to do this please
Cheers
Nigel
Maybe this: http://archivedarchivedforum2.beoworld.org/forums/t/12350.aspx
Or this: http://archivedarchivedforum2.beoworld.org/forums/p/5566/40442.aspx
BTW it's a bit tricky trying to search the archived forum - had to use google!
Many thanks Guy. Had to hunt around for one with a reset button, but found one in the end!
Glad to help, and that it worked!
If Keith is reading this perhaps someone could look at the Archived Forum search function - it doesn't seem to be working but would make queries like this much easier to answer.
