i have a Bevision 8-32 which should be upgraded to the latest software, but the technican had trouble getting the software to upload. The PUC table on the other hand was sucessfully updated.
So the hardware should be working fine. The technican considered that the software on my 8-32 is to old to recognize the new build.
My information is that build 140 is the latest release. But since this is not displayed in the service menu, what PW should i read? The actual PW is 34f.
Has any one the corresponding PW and other infos for Build 140?
Thank you in advance.
Ralf
Build 140
PW328: 34.23f
FEP: 33.32n
System module: 32.30z
Thanks MCP!,
So the update was sucessful! I have the same PW328
