TV was working just fine. I turned it off and popped out to the shops. Came back half hour later and now TV won't turn on. I unplugged from the mains, plugged back in - green light comes on for about a minute then goes off. Nothing I press on BeoRemote seems to have any affect. Any suggestions?
Pat:Hi, Maybe try to re-pair the remote with the tv?
Phew. Thanks Pat. That worked.
