BEOLAB 8000 SPEAKER
Colin
Whitstable
Posts 25
Silver Member
Colin Posted: Thu, Aug 30 2012 5:18 PM
Hi all
please help? one of my speaker lights stays green with no sound i have tried all the normal tricks changed the speakers around and switches ? i had them upgraded two years ago< i think its a internal fuse is this something i could attempt to fix my self?????????
regards all
colin
THOUGHT I WOULD TRY AGAIN AS I GOT NO RESPONSE WHEN I ORIGANALLY POSTED THIS
MANY THANKS COL
Ronnie
Milton Keynes, UK
Posts 110
Ronnie replied on Thu, Aug 30 2012 5:29 PM
Check the internal connections to the speakers.
JC
West Yorkshire
Posts 764
Silver Member
JC replied on Thu, Aug 30 2012 7:00 PM
Are you sure it is not set to LINE in the connections?
Jonnie
Chaka
Chicago
Posts 312
Chaka replied on Fri, Aug 31 2012 1:38 AM
I know you said you changed the speakers around, but did you change the wires around?  Problem I had. New cable fixed the problem.
Page 1 of 1 (4 items) | RSS
