I`d set the BS5E to A.OPT 4 - if possible, I have no BS5E - BV to V.OPT 2, BS4 to A.OPT 0 and PM to A.OPT 0.
You can program macros to your Beo5:
Map A.AUX and LINK N.MUSIC to the button N.MUSIC. This will start up the BV in audio mode, activate BS4 in Aux mode and start up the BS5E N.MUSIC. Volume wheel should respond to your BV volume setting.
To open PM airplay port program a button that activates A.AUX - Link A.AUX. Volume wheel should respond to BV. You can control your PM via your itoy or Beogram. Set PM to fixed level output.
Volume control in such a setup should never respond to Link sources (BS5E). You can reprogram the volume wheel as said before.
Stefan
