Hi everybody me again with connection problems ha ha. I have recently bought a project genie record player and want to connect it to my overture. The problem being that it comes with a red and white cable with a seperate earth cable. Can I convert this into din ?
Many thanks
nathan
Benny26boy: I have recently bought a project genie record player and want to connect it to my overture. The
I'd buy an appropriate cable from Steve ... http://www.soundsheavenly.co.uk/bando-rca.htm
Benny26boy: Hi everybody me again with connection problems ha ha. I have recently bought a project genie record player and want to connect it to my overture. The problem being that it comes with a red and white cable with a seperate earth cable. Can I convert this into din ? Many thanks nathan
Yes, you can. With a bit of soldering skills you can easily do it your self. Or buy a converter cable in a local shop, they're not so expensive!
Brengen & Ophalen
You will also need an RIAA pre amplifier.
//Bo.A long list...
BO: You will also need an RIAA pre amplifier.
Bingo.
