Looking for help. BeoLab 3500 no longer working in ML/NL set-up
This post has 15 Replies | 0 Followers
Beoberg
Odense, Denmark
Posts 315
Beoberg Posted: Sat, Jul 22 2017 2:30 PM
Hi guys,
I have just removed my BeoSound 5 / BeoMaster from my home system as I will be having another audio source soon. My set-up has previously consisted of BV11-55, BS5/BM5 and a BeoLab 3500 in another part of the ground floor. As I have removed the BS5/BM5 the BeoLab 3500 has stopped working and I cannot figure out what is wrong. I have tried a couple of things in the menu of the BeoLink Ml/NL converter without any luck. The BeoLab 3500 is no longer showing the time and will not react on any IR-inputs.
Can anyone please advise what role the BeoLink Converter should have? AV Master, Audio Master, Video Master, Audio Slave or Source Center?
I have set the TV to VM 2. Is this correct?
Thanks a bunch,
Best regards,
Frederik
BeoVision Eclipse 55, BeoPlay S8 (sub+rears), BeoPlay A9 MKII (living room), BeoVision Avant 32 DVD (retro gaming, basement), BeoLab 4000 (entertainment room, basement), BeoSound 8 (workshop), 2x BeoPlay S3 (PC), BeoPlay A1, BeoPlay H2/H3 (on the go)
Hiort
Sweden
Posts 2,895
Hiort replied on Sat, Jul 22 2017 4:11 PM
Beoberg:
Hi guys,
Thanks a bunch,
Best regards,
Frederik
BeoVision 11-55 MKI (primary), BeoLab 9 (front), BeoPlay S8 (sub+rears), BeoSound 5/BeoMaster 5, ML/NL converter, BeoVision 6-26 MKIV (bedroom), BeoLab 3500 (dining room), BeoVision Avant 32 DVD (retro gaming, basement), BeoLab 4000 (entertainment room, basement), BeoSound 1 old (leisure room), BeoSound 3 (workshop), 2x BeoPlay S3 (PC), BeoLit 12 (kitchen), BeoPlay A1 (everywhere), BeoPlay H2/H3 (on the go)
Think your problem is that you have no power source on the ML side, since your BS5 is removed.
You need a B&O power box.
I have one for sale if you are interested Smile
Beoberg
Odense, Denmark
Posts 315
Beoberg replied on Sat, Jul 22 2017 4:21 PM
Hi Hiort,
That sounds plausible Smile Can you PM me the details?
Can anyone confirm that this might be the solution?
Best regards,
Frederik
Hiort
Sweden
Posts 2,895
Hiort replied on Sat, Jul 22 2017 9:01 PM
Beoberg:
Hi Hiort,
That sounds plausible Can you PM me the details?
Best regards,
Frederik
I’m sure that is the solution. I had a similar setup. The Bv11 do not power the Masterlink.
You connect the power box to the NL/ML converter.
Will pm the details.
Hiort
Sweden
Posts 2,895
Hiort replied on Sat, Jul 22 2017 9:55 PM
This is the setup instructions
Beoberg
Odense, Denmark
Posts 315
Beoberg replied on Sat, Jul 22 2017 11:24 PM
Great, thanks. I'm interested in buying your power box then Yes - thumbs up
Master123456789
Posts 237
Hello Beoberg and others. Did the power box got it to work?
I am very interested in the answer. Thank you very much :)
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Tue, Aug 29 2017 6:35 AM
Master123456789:
No Audio or Video Master in the ML chain; the Powerbox is mandatory to let it work.
So only a BS3500 or BL Passive (used as ML device; not as solemnly an amplifier) or BL2000 than the Powerbox is mandatory.
Hiort
Sweden
Posts 2,895
Hiort replied on Tue, Aug 29 2017 1:08 PM
Master123456789:
Yes. I had that confirmed from Beoberg since he purchased the power box from me Smile
Master123456789
Posts 237
Thank you. I also need a master
I don't think my Beovision 8 can work as a master, also I want to let it work without the BV8.
Now I need to find a power box - where can I buy it? In Denmark or on ebay? Or maybe second hand?
Hiort
Sweden
Posts 2,895
Hiort replied on Tue, Aug 29 2017 2:05 PM
Master123456789:
I bought mine from my B&O dealer.
Master123456789
Posts 237
In the UK? What was the price? :)
Master123456789
Posts 237
And what do I need for cables?
  • A CAT7 - like this https://www.av-cables.dk/cat-7-s-ftp-graa/cat-7-s-ftp-lszh-netvaerkskabel-graa-0-25-m.html
  • USB - https://www.av-cables.dk/usb-a-usb-b/usb-kabel-2-0-usb-a-han-usb-b-han-0-25-m.html
  • and CAT7 to masterlink?
Master123456789
Posts 237
Nobody got a ML power box for sale? Or where I can buy it? :)
Hiort
Sweden
Posts 2,895
Hiort replied on Wed, Aug 30 2017 7:43 AM
Master123456789:
Sweden in my case. Recall it being around 110 euro
Hiort
Sweden
Posts 2,895
Hiort replied on Wed, Aug 30 2017 7:45 AM
Master123456789:
A CAT7 - like this https://www.av-cables.dk/cat-7-s-ftp-graa/cat-7-s-ftp-lszh-netvaerkskabel-graa-0-25-m.html USB - https://www.av-cables.dk/usb-a-usb-b/usb-kabel-2-0-usb-a-han-usb-b-han-0-25-m.html and CAT7 to masterlink?
See the setup instructions below in the thread
Page 1 of 1 (16 items) | RSS
