I recently bought a Beolab 14 5.1 and am looking for a receiver. According to the spec, each satellite is rated 140 watts and 280w for the sub. I am currently looking at Denon X3300H (105 watts per channel) or the X4300H (125 watts per channel).
Since I am new to all this, I was wondering if I can get some feedback on whether or not either will be sufficient to power the Beoalb 14 5.1 or an even higher-end receiver like the Denon X6300H which has 140 watts per channel is needed.
Thanks!
Hi and welcome to Beoworld.
And congrats on your new purchase.
Don't worry about watt-figures - the BL14 set is a powered set (means already with amplifiers built-in).
This might help:
http://www.echo14.com/wp-content/uploads/AudioVideo-Receiver-connected-to-BeoLab-141.pdf
https://www.bang-olufsen.com/~/mediaV3/Files/User-Guides/BeoLab-14/beolab14_multilanguage_guide.pdf
Good to be a part of this community and thank you very much for your help!
