Hi, I have just bought an old house with a Lexel EIB/KNX system, anno 2002.
Could anyone here propose a suitable interface that would enable the BLMG to talk to this system?
There is a RS 232 port on the KNX bus. Could it be used ? Or should I install a suitable ip interface? Which would you recommend?
Best regards!
