If you have wake-on-lan activated (which isn't the default), try to turn your V1 on via the Bang & Olufsen app.
Well I've had a similar issue at the beginning of the 4th year after our purchase and they tried replacing the IR sensor but the problem was eventually located on the main chassis.
I hope the source of your problem is located elsewhere and easily fixable at a reasonable price because the chassis is a very expensive part.
Best of luck.
Just out of curiosity, was the issue resolved (and how)?
