Anyone who has a DVD controller for sale?
An American friend of mine bought a Dvd 2, and had it shipped to New York. But in the States, they don't use scart, the dvd 2 is dependent on scart for IR. So he was thinking if he can get the controller, and switched the controller's ir to a bang & olufsen ir, he might be able to control it!
On behalf of a friend
Brengen & Ophalen
The original DVD controller translates the data in the datalink from the scart to ir signals to some DVD brands like Onkyo, Philips, Panasonic.
Then the voltage used in the States. Some poweradapters probably can't handle the voltage.
So, does the tv has a STB output, like an Avant US? Maybe worth trying to connect this output to pin 8 on the scart from the DVD2.
