Hi
I have 2 pcs of Beosound Overture , which have the same fault. They cant find FM stations when searching the FM band. . If the frequency are manually set by the keyboard stations can be heard, but the sound is a bit lo and slightly distorted. Does anybody have a solution on this ?. I Believe tha problem is around the FM IF cuircuit IC LM 1865 .
I believe this is a problem others must have had, and someone had found the fault in the faulty tuner Board.
Best regards
Gert
