Hello.
Can somebody advise me of the size/shape of the small tool used for adjusting the screws on the underside of the BeoLab 2? I want to get some tilt!
Thanks, Jon
I have no idea, but can you say what you mean by tilt? The BL2 is a sphere on a rubber ring, are you talking about an audio adjustment?
Jeff
Hi Jeff, yes I mean tilt in the the physical sense. If you loosen the screws on the underside the sub can be tilted, as per this pic
http://www.davidlewisdesigners.com/files/images/300_BeoLab2.jpg
To bring the BL2 into this position you simply have to lift it grabbing it in the middle hole on top, without actually lifting it from the ground. In this positioon you can easily tilt it without any tool.
hfat
