Where can I buy a replacement motor for the record deck?
Thank you and regards
Rodderic Laird
New parts are no longer available.Is it missing or just bad ?If missing, you will have to find one from a donor (note that it's probably a 110V motor).If bad, you will have to take it apart, clean and lubricate bearings etc.
If this is a wanted ad, please keep it in the appropriate forum section.
