Will a BM6500 tuner work in a BM7000 ?
This post has 3 Replies | 0 Followers
Weebyx
Denmark
Posts 1,213
Weebyx Posted: Wed, Oct 11 2017 7:59 AM
Hi... My damaged BM7000 is now working, except for the tuner which is totally dead and beyond repair.
My question is, will a tuner from BM6500 work as donor, without RDS off course, but are there major changes in the processor control of the tuner, that will interfere ?
My own logic and looking at the service manual, says that it will work.
What do you guys say ? :)
/Jacob
tournedos
Finland
Posts 7,357
tournedos replied on Wed, Oct 11 2017 12:49 PM
I seem to recall I once tried swapping these (connected a 6500 tuner board to a 7000 amp) to isolate a problem and it worked. So my answer is a definite maybe Big Smile
--mika
Weebyx
Denmark
Posts 1,213
Weebyx replied on Wed, Oct 11 2017 1:46 PM
tournedos:
Great :)
I will try later tonight.
/Jacob
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Wed, Oct 11 2017 9:27 PM
It will work.
The RDS part is located next to the processorboard at the front. These cans are the same as used in the ouverture etc.
There is a change that you need to re-adjust the FM indication (mis-alignment showing 92.7 instead of 92.6Mhz.)
Page 1 of 1 (4 items) | RSS
