Beoline not registering phones
This post has 7 Replies | 0 Followers
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 Posted: Sun, Oct 8 2017 9:05 AM
I got a new unused Beoline and plugged it in. It will not register any phones . The light stays red on it and the 6000 and Im getting an alert on the Beocom 2.
Are beolines/beocoms country specific ? I would be surprised if it was the case particularly in Europe.
Any suggestions ?
Guy
Warwickshire
Posts 2,590
Guy replied on Sun, Oct 8 2017 10:27 AM
There could well be a compatibility problem with older phones and newer Beolines.  It's all explained here, but you have to read it carefully!
https://www.beoworld.org/faq_view.asp?id=74
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
There are country specific in terms of language and power, but in Europe the phones will work between countries.
Below is a compatibility chart which will help you. Did you unregister the phones from any other base unit before trying to register with the new Beoline?
Regards Keith....
valve1
Posts 1,502
valve1 replied on Mon, Oct 9 2017 10:08 AM
Thanks for both replies but no joy so far.
Unregistering phone is 9#9#9#*int   ?
My 6000mk 2 (1100193)will register no problem with my old base  it will not register to new Beoline.(1113070)
My BC 2 which just had its software updated and a new battery (1100121) will not register with the old beoline (can find numbers) nor the new Beoline (11103070)
The reason I want to change Beoline is the old one is 3 pin socket and the new one 2 pin european power sockets.
Complicated !
Ralf
Hamburg Germany
Posts 189
Ralf replied on Mon, Oct 9 2017 10:33 AM
I can confirm that a Beoline ISDN works with a Beocom 5, in your overview there is no cross,but i have it working since years now, together with Beocom 6000 and Beocom 2 each MKII Versions. The Beocom 5 is from 2011.
Guy
Warwickshire
Posts 2,590
Guy replied on Mon, Oct 9 2017 11:10 AM
Could the 'new used' Beoline actually have been used before?  If so, perhaps it already has too many phones registered to it?
There's some good info here about resetting both bases and phones, and also how to remove phones from a base: http://archivedarchivedforum2.beoworld.org/forums/t/3649.aspx
valve1
Posts 1,502
valve1 replied on Thu, Oct 12 2017 11:55 AM
Sorted Big Smile
It was down to me . I thought I only need enter code 9#9#9*int , I didn't realise I had to scroll down beyond that to press "reset phone"
Thanks for all the help
Guy
Warwickshire
Posts 2,590
Guy replied on Thu, Oct 12 2017 12:00 PM
Great news - thanks for letting us know Smile
Page 1 of 1 (8 items) | RSS
