I may have mentioned this before, but I have a beolink 7000 that has new batteries installed.. It lights and sits up on a table, but doesn't respond. Is there another battery inside that needs to be changed? It won't respond to any touches on the blue screen. It used to work before I had the battery pack changed. Any ideas? Thanks so much.
thetandyman: I may have mentioned this before, but I have a beolink 7000 that has new batteries installed.. It lights and sits up on a table, but doesn't respond. Is there another battery inside that needs to be changed? It won't respond to any touches on the blue screen. It used to work before I had the battery pack changed. Any ideas? Thanks so much.
Didn't you read the responses you got on your former post ?
Please respond to that thread instead of just starting new ones, that makes it difficult to help you.
/Jacob
