Beo 5500 system
David
Guildford
Posts 11
David Posted: Tue, Oct 17 2017 3:05 PM
Hi folks following a recent question, may I ask another, has the 5500 system a memory chip within its workings, and if so could it be damaged - as I've recently had to reload all my radio stations following a power cut, which hasn't had to be done  before.
David
Guy
Warwickshire
Posts 2,590
Guy replied on Tue, Oct 17 2017 3:14 PM
There's a 3V battery on the main processor board that may well need replacing.
EDIT:  You can see the battery here: http://archivedarchivedforum2.beoworld.org/forums/t/29945.aspx
David
Guildford
Posts 11
David replied on Sun, Oct 22 2017 10:59 PM
Hi Guy, I tried taking your link to see, but had trouble following, so if you would be so kind, where is this battery located, today I looked inside the MCP but cannot find one there, so is it somewhere else and also is it easily get at able.
Thanks in advance
David
Page 1 of 1 (3 items) | RSS
