Hi all, I am a newbie here and thanks in advance for any help :)
Basically I currently running a BV7 MK3(connected to BLs) masterlinked with BM5.
V.OP=1, A.OP=0 for the set up.
I recently moved to a place with 4 passive ceiling speakers with wires ended where I placed BM5.
I am thinking to hook up all the speakers(just for the sake to use them since they are there :P) with BM5.
What options do I have? I just want to see if there are ways I can play with them?
2 of them are in the living room and other 2 are in the dining room.
All ideas welcomed!
Another question is, IF I have V.OP=1,A.OP=1 and speakers connected to BM5, would it be possible to have all speakers on(the ones from BV7 and ones from BM5)?
Thanks!!
MChilly
