When I press Start, the tonearm travels to the record, lowers to the record, but then immediately raises and returns to the home position and the unit powers off. I’m just a novice user. Where do I even start looking for the problem? There is a MMC 20EN stylus on it.
Hi there,
Just for interest sake,have you tried manually to play another track? (Not the first track- pick track 3 or 4).
and see if the tonearm still behaves the same way.
I'm not a technician, but it would be one thing eliminated in your trouble- shooting.
If it plays OK , then I would think that some adjustment would be needed to the tonearm or sensor.
Regards
Noel
