met welke kabel kan ik mijn beomaster 7000 verbinden met de sonos connect?
what kabel do i need to connect my beomaster 7000 with the sonos connect
Deze:
https://www.soundsheavenly.com/bang-olufsen/52--2rca-5pd-.html
Van RCA naar DIN input-kabel.
Hi Roos,
To play streaming music from the Sonos to the Beomaster 7000, you just need this cable:-
This can connect to the Tape, CD or Phono input on the 7000.
Kind regards, Steve.
Steve.
