Sky updated the SkyQ silver and the Sky Minis overnight. The Beo4 has been controlling the boxes very well since the PUCs were installed on two BV-10 but now only has limited abilities. No fast forward or rewind and two presses for almost every other operation in the Sky EPG. The Sky remote operates normally so I have no idea why the Beo4 no longer works. Anyone else having the same problems ?
I have had the upgrade to SkyQ with my Beovision 7 40 and a Beo4 without the navi button and everything works like it used to. Though I have never been able to fast forward but only to jump forwards, and not sure if there are other functionality I can't use but all the menu functions work.
Thanks patcherly. It’s controlling the mini boxes that’s most changed. The main SkyQ silver box is with a beo1 remote via the BV-14 PUC and that is still fine like your BV-7.
beoair, I have my Beovision 6-26 working the same as the Beovision 7 40 but with a MiniQ and a Beo4.
