I'm considering these space efficient speakers for our new kitchen dining room. What's actually required to run it other than power and some kind of feed/hub from the I-products or should I try master link ?
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
Hi Simonbeo,
As these are passive (unpowered) speakers, you will need a power amplifier (or Beolink Passive, BeoAmp2, etc) to run these from a newer B&O TV or audio system. Older systems prior to around 1990 (eg. Beocenter 9000, Beosystem 6500, etc) have power amps built in, so they will plug directly into Celestial and Palatial speakers.
If you can please let us know which B&O products you wish to use with these speakers, I will be pleased to confirm everything you need to get them working.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
