Just get one 9500 on my desk. It clearly has a replacement panel on it.
On top original from another device and bottom replacement.
Just wondering why it is made of clear glass while original is tinted?
And whoever has changed it , did use as bad tape as original
Well better than dumpster I guess...
that's an original panel that's been in direct sunlight, quite common and i must have 4 units that have the same.
strange what the uv can do to the paint over time.
Oh. Really? That explanes bad tape.
First I have seen.
I have one liike that too. Not that uncommon it seems.
--mika
