BV 7-55 Mk?
This post has 5 Replies | 2 Followers
f5434964
Austria
Posts 206
f5434964 Posted: Fri, Apr 12 2013 11:35 AM
Dear all!
I'm considering getting an BV 7-55 - maybe as an second Life product. That's why I want to ask if there is a significant difference between the two Mk versions concerning picture quality that would justify the price?
Best Regards
elmar
moxxey
South West, UK
Posts 5,359
moxxey replied on Fri, Apr 12 2013 11:53 AM
f5434964:
I'm no BV7-55 expert - there are many other users on here who can give you better feedback - but the whole backlighting got a major revamp between the BV7-55 MKI and MKII. The MKII has local backlighting, exclusive to this TV, which gives a far even picture, with better blacks, no clouding, unlike side lit LCD panels, such as the BV7-40, BV11 and BV7-55 MKI. The MKII is generally regarded as having the best picture in the B&O range.
vlohjr1
Posts 553
vlohjr1 replied on Fri, Apr 12 2013 12:46 PM
Mkii also has 3d and the blu ray is also 3d
Regards
Vince
Sweden
Posts 357
Silver Member
Martin replied on Fri, Apr 12 2013 1:05 PM
I have BV 7-55 mark II today. I have also had the BV 7-55 mark I. Picturewise: Both Mark 1 and Mark 2 has Direct Type LED (not EDGE-led) with local dimming and Scanning backlight (see below).
The real differences is as follows:
Mark I:
Direct type LED with Local dimming and Scanning backlight with 96 different dimming zones. No 3D. The inbuilt Bluray-player is a bit slow to load Bluray and the Bluray player don´t support DTS Master Audio-format. The Tv has a projector out: DVI (no HDMI)
Mark II:
Direct type LED with Local dimming and Scanning backlight with 512 different dimming zones. Can handle 3D, but there is some crosstalk and other issues with the 3D-mode. 2D is very good and I think it is the best 2D-picture in of all B&O-TV:s today. The inbuilt Bluray-player is much faster than the old one (in Mark 1), and it supports and handle both Dolby True HD and DTS-Masteraudio. The Tv has a projector out: HDMI (with 3D-support).
This is the major differences between Mark 1 and Mark 2. Both TV:s has Beosystem 3 as a Video-engine.
Regards
Martin Strom
SWEDEN
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only),  Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
f5434964
Austria
Posts 206
f5434964 replied on Fri, Apr 12 2013 5:38 PM
Thanks to all for your quick and detailed answers; so the Mk II would be the better decision.
Best regards Elmar
papas_spiros
Posts 24
Hello everyone,
Very helpful analysis between BV 7-55 Mk I and Mk II.
Please let me know the TYPE of BV 7-55 Mk I and the TYPE of BV7-55 Mk II.
Is the Mk II the latest or there is a Mk III as well ? If yes what the TYPE ?
Thank you.
Spiros.
Page 1 of 1 (6 items) | RSS
