Charging issue with Beoplay H9
This post has 6 Replies | 2 Followers
radau
Stockholm
Posts 3
radau Posted: Thu, Jan 19 2017 5:37 PM
Hi everyone,
I have a question to all those who own the new Beoplay H9 headphones (or even other wireless Beoplay headphones like H8 and H7, as their battery seems to be similar/identical).
After charging the headphones until the LED shows a steady green light, I regularly observe that the battery level of the headphones displayed on my phone is only 90%, immediately after connecting the seemingly fully charged headphones. As the battery level is only shown in 10% steps on the iPhone, I assumed the precise battery level to be somewhere between 90% and 100%. On my smartwatch it somehow shows the battery level in 1% steps, and my assumption proved right, as there the level is always displayed to be around 97% right after charging, so not 100% even though the LED is green. Even when I then charge the headphones again right away, and it blinks orange for some time, I never get above 98% displayed battery level after reaching the green light.
This seems just a minor issue of course, but I'm still curious if anyone experiences the same with their headphones?
Also, I tried connecting the headphones while still on the charger (green LED) and it shows the battery level to be 100%, but right after disconnecting from the charger it switched to 90% on the iPhone and 97% on the smartwatch. Does the battery maybe just need to be recalibrated by the software? Thanks in advance for any suggestions!
elephant
AU
Posts 8,219
elephant replied on Fri, Jan 20 2017 1:11 AM
I believe I have seen 100%
And also that the headphones will hold the charge for quite some time when not being used
Have you tried checking via the BeoPlay app ?
BeoNut since '75
radau
Stockholm
Posts 3
radau replied on Fri, Jan 20 2017 8:02 PM
elephant:
I have, but it only shows that little battery icon in the upper right corner, right? It looks almost full (as in 90%) but not completely full.
jonnyb
Posts 92
jonnyb replied on Sat, Jan 21 2017 12:32 PM
I have exactly the same problem with my H9.
Even when fully charged with the green light, my iPhone will routinely only report a maximum of 90%. I have managed to get it to display 100% once, when I completely drained the battery and recharged it fully. I have not done this since so I only ever get a maximum display of 90% because I never fully discharge them in real-world use.
It doesn't seem to be an issue, as I am getting the promised battery life out of them - it's just that it's not being reported accurately. Perhaps a software update to the H9 can fix this.
radau
Stockholm
Posts 3
radau replied on Sun, Jan 22 2017 11:23 AM
Good to hear that I'm not the only one with the issue! And yes, I also get the promised battery life, so you're probably right with your assumption that it's only a matter of the software reporting a wrong battery charge.
TCMuffin
Cardiff
Posts 3
Hello
I have a similar problem...the charge only lasts about a day or so, even when the headphones are not used?
In addition if I try to charge the headphones (via the USB cable) whilst they are plugged into my laptop, I hear a loud hissing sound and I'm not sure if the noise cancelling function is working as I can't hear a different between it being turned on and off :(
Has anyone else noticed this?
john2691
Posts 1
I reached out to B&O about this issue and was told that since it can only report in 10% increments on certain devices, it will round down to the nearest multiple of 10. Thus, a 99% charge is reported as 90%. Annoying, and it's possible that it could be fixed at some point, but for now at least I know it's not a defect.
Page 1 of 1 (7 items) | RSS
