hi all,
just bought a beovision 7 32 MK5, not picked it up yet, i asked the seller about the pin code and they say its never been needed to be put in to make the set work.
i know nothing about these pin codes, does the owner have to input the code then to start it working?
when would you need to re input the pincode when the sets been unplugged for a while? as they tell me its been unplugged for weeks and when re energized it works straight away without the the need to input any code number.
just want to make sure i know all there is to know about the pincodes with the beovision 7 32 and how to set it going and disable it etc before i hand over the cash.
phil
See page 22 of the User Guide here: https://www.bang-olufsen.com/en/product-support/picture/beovision-7-32
thanks for that, seems you have the option to input the code or not, and hopefully they havent done this as i think B&O require the original purchace recipt to prove the set is yours which the dont have so getting a pin off B&O will be difficult i think
