I have a Beosound 3000 mk2 connected to a core. I want to use my Beoremote One instead of the Beo4 remote. Some functions work, but I can't seem to get it to work 100%. Is there a solution for this?
Best regards
There is a beo4 mode on the BeoRemote One, so if your beosound is your only product controlled by this beoremote, you may give a try...
diisign.com
