Hallo, I bought some used BEOSYSTEM 2300, because of my enthusiasm for the looks.
Ingenious!
Unfortunately, the doors do not close completely or they only close 1/2 the way at some of the Beosystems.
How can I adjust this - or is something broken?
Thanks for your help.
There's some stuff about it here: http://archivedforum2.beoworld.org/forums/t/3813.aspx?PageIndex=1
EDIT: Actually this thread's better: http://archivedforum2.beoworld.org/forums/p/4707/42777.aspx#42777
Of course the cable may have come of the pulleys or there could be a different problem, but the thread should help.
Thank you very much. I will look there.
Okin
