Help needed
my new avant ng tv been installed next week and I have sky hd box what is correct puc to use?
at the moment have a beovision 11 and is set to Thompson hd but suspect it will be different for avant been bluetooth
my engineer here in canary isles very good but not very familiar with sky tv
many thanks
malcolm welborn
It should be exactly the same.
I had a BV14, same platform as the Avant NG, and i believe the PUC was exactly the same ( and the same i used on my BV12-65)
So the PUC choice should be platform / remote agnostic.
many thanksall working well
malcolm
